Already changed it to 1.75mm.
Didnt change anything ?
Me too same problem with 3.5 and four different priner
Printer is locked to the 2.85mm branch*, Filament is hard coded to 2.85mm in three reference files. Changing it will not change the slice.
* Also means you only get 2.85mm filament material definitions.
This has been identified as to be fixed in new version.
I have the same problem and actually I first thought it was because I upgraded to bullseye duct but LUCKILY it was just the software. Im just going to install Cura3.4 or 3.6+
tinkergnome 918
