Solex 0.25 Noozle - Simplify3D setting ?
curieux
Posted · Solex 0.25 Noozle - Simplify3D setting ?
I can't get any reasonable results with your 0.25 mm noozle with my ultimaker 2+ .
I use simplify3d for the slicing process.
Does anybody have useful simplifyor Cura  parameters for me in conjunction with this noozle diameter ?
e.g.
Extrusion Multiplexer
Extrusion width
Primary layer Height
First Layer Height 130
  Default Printing Speed mm/min
The result is always the same wih different parameter ( see attach)
the object is detached
sincerely
curieux
          • Confused
        • 4 replies
