Number of layers / height mismatch
DimiZ
Posted · Number of layers / height mismatch
I have been using cura for a while and have been getting very good results. Since around the upgrade from 3.4.1 to 3.5 I noticed a mismatch between the number of layers and the the model height. For example, if a model is 6.0 mm high, using a 0.2 mm height used to render 30 layers. Now (since the upgrade) it renders 29 layers (see screen shot).
I went through all the setting but I could not find what might be wrong.
Do you have any ideas what settings I need to adjust?
Thank you in advance
Kind regards,
DimiZ
