7 hours ago, fbrc8-erin said:You can disassemble the printhead and reinstall it. There are some photos of the process on this thread.
Just curiius
I assume this setup is the same for the S5.
If this is true should we keep a couple springs as spares or is the risk of failure and or issue well below the proverbial radar?
What is the part number for the spring and if replaced is there anything else required at the same time?
Thank you
fbrc8-erin 267
