Merge parts in cura
Arturas
Posted · Merge parts in cura
Could someone tell me why its happening and how to make good. I trying to merge to part in one to print two colors but its merge me wrong as should be.
I cut in two peaces with Autocad. but how to set up cura to merge right?
Thank you
    Cura is aligning the coordinate systems. If the cutted pieces get a new CS, merging will fail. Try to cut and keep the original CS. Maybe you could use Fusion 360.
    I never used Autocad or Fusion 360, but since the problem is the coordinate system, perhaps you could change the center of the two cut pieces in and place it as if it was the complete piece? Thus, for the cut pieces, the {0,0,0} coordinates would be located on the wall that will stick with the other cut piece. Then CURA should be able to merge them without a hitch.
    Brulti,
    Autocad, before you slice object , object has gravity center individually, after you slice in two ore more parts, each part has individually gravity centers. when you transferring all parts in cura i can i alight two coordinate to match. But one of (x,y) i don't know to mach in one peace. it could be 0.01 different and it wont be one big peace.
    Sorry, I have no experience with Autocad. With a center-of-gravity-coordinatesystem it will fail. yes. Maybe you could use a World-Coordinate-System.
    all issues sorted after new cura released
    good. but what changed?
