kmanstudios 1,117
@ahoeben is correct, I do not use octoprint.
And maybe memory leak is not the correct term. But I notice it increases in CPU usage and will interfere with other programs if used over a period of time. I can at least track the CPU usage. I will see what else I can offer as well.
When I use the program, its usage balloons and never goes back down even when reset or even rebooted. I will try to get around to just showing this usage with screenshots a bit later today.
I also do not use the camera as the machines are right around me and I am not gone long enough to worry about it at any given time.
Top Posters In This Topic
3
18
16
8
Popular Days
Oct 23
14
Oct 22
9
Oct 18
7
Oct 17
6
nallath 3 posts
ahoeben 18 posts
kmanstudios 16 posts
Adam324 8 posts
Popular Days
Oct 23 2018
Oct 22 2018
Oct 18 2018
Oct 17 2018
Popular Posts
ahoeben
A cause for a memory leak in both OctoPrint Connection plugin and Cura Connect has been identified. I have created a workaround for OctoPrintPlugin. If my workaround works without (too many) sideeffec
Shadowman
I for one; thank you for your ongoing effort to share as able with the development team to insure that this is corrected. Takes care.
kmanstudios
I am not running the cam or any other thing but Cura and Cura Connect. System is i7-770K 4.2 Ghz 32GB Ram Nvidia GForce GTX 1080 Win 10 ? Just opening Cura
Posted Images
nallath 1,080
I've tried switching on the camera with Cura connect a few times on Fedora, but I don't get the memory leak (or any network issues ?
