Language problem
johank
Posted · Language problem
Hi Daid,
I'm one of the Swedish users of Cura, and I have some problems. Using the standard settings of Cura, the program wont slice anything 3 days a week. All I get is a Ubuntu crash report, however Cura keeps running, and creating more crash reports.
I have located the source of this error to the fact that my Ubuntu is set to use the Swedish language. The problem is that 3 weekdays in Swedish contains special characters (Måndag,Lördag,Söndag), and when Cura generates ascii string from "{day}" in start.gcode these days are represented with ("mån","lör","sön"), which gets a representation containing something like 0xC3A5. If I start Cura with "LANG=en_us; cura", all is well, and my model slice.
the error is reported like:
Traceback (most recent call last):
File "/usr/share/cura/Cura/gui/sceneView.py", line 420, in _onRunSlicer
self._slicer.runSlicer(self._scene)
File "/usr/share/cura/Cura/util/sliceEngine.py", line 116, in runSlicer
for k, v in self._engineSettings(extruderCount).iteritems():
File "/usr/share/cura/Cura/util/sliceEngine.py", line 259, in _engineSettings
'startCode': profile.getAlterationFileContents('start.gcode', extruderCount),
File "/usr/share/cura/Cura/util/profile.py", line 797, in getAlterationFileContents
return unicode(prefix + re.sub("(.)\{([^\}]*)\}", replaceTagMatch, alterationContents).rstrip() + '\n' + postfix).strip().encode('utf-8') + '\n'
File "/usr/lib/python2.7/re.py", line 151, in sub
return _compile(pattern, flags).sub(repl, string, count)
File "/usr/share/cura/Cura/util/profile.py", line 685, in replaceTagMatch
return pre + time.strftime('%a').encode('utf-8', 'replace')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 1: ordinal not in range(128)
I'm not a python guy and I don't know how to fix this, but the problem is as described above.
On a related note, I really must say I appreciate the new slicing engine. The only question I have so far is if Cura isn't a little to eager to slice the models. I know you don't like unnecessary stages in the printing process but I find the ever appearing slice process indicator a little annoying. The fact that Cura is eager to slice resulted in quite a few error reports as well.
best regards,
Johan K
        • 9 replies
