Escala automatica
idrivn
  • 3 years later...
Posted (edited) · Escala automatica
This might be what you are looking for.
If you load the Mesh Tools plugin from the MarketPlace, and then restart Cura you will get this added Menu option:
Which will lead to this dialog.  Under "Unit for files that don't specify a unit" there are options:
If you typically design in cm then the model will be scaled by 1000%.
The XYZ of the model will reflect that size in mm.
The "scale" of the model will then be altered to consider this new size as "100%".
In this example, the model was actually designed in mm (22 x 1 x 16) but I have set the Mesh Tool to cm.  You can see that the model has been auto-sized and the XYZ "scale" boxes reflect the new size (220 x 10 x 160).  This new size is now "100%" rather than 1000%.
Edited by GregValiant
        • 6 replies
