Well, there's a few problems out of the way!
Not sure how it happened but those two jumpers were missing. I added them back and power returned to the always-on fan and heaters. Thanks for the suggestion!
Unfortunately, my dual fan problem persists. Not certain how to fix that.
tinkergnome 929
UMO+ uses the main board 2.1.1, right?
There are two "Safety"-Jumpers that (dis-)connect the 24V line if (not) installed - i would check those first
(between LED- and endstop-connectors).
And AFAIK there's a relay for the 24V line near the power connector - this may be faulty - (measure the voltage there).
