Could it be that your export to STL is in too low resolution? So the STL-triangles get too big? You need to look at the STL-file in an STL-viewer, or look at how it shows up in Cura.
Maybe there could also be too much play in the printer, but before looking into the hardware, be sure to sort out any wrong STL-export settings first.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
geert_2 557
