3 minutes ago, Shadowman said:I am looking forward to Ultimaker Cura 3.5...3.6... or whatever it becomes being debugged as I understand that the Prime Tower is more stable.
For now; it is Ultimaker Cura 3.4.1.
I mean there are some options in 3.4.1. to make the prime tower more stable, but I don't know what to tune. Maybe you can add a brim or make it wider - but personally I have never played with these settings.
And yes, in 3.5 the prime tower should be more stable (but only the tower not the sw version ? )
Shadowman 53
I see the same; always along the one vertical edge which is often the ending point for the Print Core extrusion prior to it heading to Prime Tower.
If I were to guess; the retraction is simply slow when compared to how quickly the Print Core moves towards the Print Tower and because it is support material it has not been a concern presented by many.
Like you; I would like to see it crisper looking and yet I also share that the PVA support has allowed us to do much so I have not thought much about it because within minutes of the print completing it is getting a bath to remove all of it.
Enjoy
Smithy 790
I will try to explain the behavior we can see here.
First, PVA and the BB print core with its different inner shape, tends to drip more than PLA and the AA print core.
And when one layer has finished and the head moves to the prime tower a retract happens. But a retract don't mean that the nozzle stops immediately to extrude material. So the filament will be pulled back, but there is still some melted material in the nozzle and this material drips out, resulting in those strings.
Shadowman 53
Perfectly understood.
The only time that this has ever caused me any mechanical concern is when ....... the Prime Tower falls over at which point the mess can become extreme and even find PVA being integrated into the print.
Thank you
