Or maybe L2 got burnt? If there is 5V at U6 PIN 12 then check on the other side of L2 at TP16 perhaps.
- 2 months later...
ok sure thing is this borad is dead not connecting to usb but still it has the d7 led on when power is connected
i better get another new board
thanks @gr5
Unless you have multiple UM2's that you want to keep the same for a consisted workflow, I would recommend replacing the board with a Duet3d board. Basically modernize your machine for less money. It's more silent, and it's network connected, controlled from any device that runs a browser.
1
i will consider it .thanks
gr5 2,094
It would have been best to work on those wires with the power off. Obviously now.
So you probably only damaged one or two components. The schematic is here - about half way down this pdf:
https://github.com/Ultimaker/Ultimaker2/blob/master/1091_Main_board_v2.1.1_(x1)/Main Board V2.1.1.pdf
The most likely broken component is U6 which is an A4403GEUTR-T made by allegro microsystems. I'd make sure pin 1 was at 24V and pin12 was not at 5V and if so I'd probably just replace that. It's possible something else was damaged but I suspect only that part got destroyed. So if you are good with surface mount you could try replacing it.
Or you could get a new PCB either from Ultimaker or you could get a knock off from china. The knock offs are a bit different - with removable stepper drivers.
