Just now, tinkergnome said:
What does this exactly mean?
How do you initiate the pause (manually on the printer?)
How do you change the material (with the menu function on the printer or...)?
It's a UM2+ and just using Cura software so I hit 'pause' on the machine, select 'change material', change as normal letting the material flow smoothly through the nozzle for a few seconds before finishing the material change process and then hit 'resume print'.
tinkergnome 926
