Thanks for your comment.
Regarding this page it must be a Cura-bug.
https://ultimaker.com/en/resources/52029-manage-printers
I have tried to rerun the wifi setup, but it has no effect when i´m using LAnN instead of Wifi.
The API-method .... is unknown for me.
Smithy 1,141
It is not possible to rename an UM network enabled printer via Cura, don't ask why, I don't know.
2 options to do that:
1) rerun the wifi setup on your printer, there you can set a new name for the printer which is then also shown in Cura
2) Use the API of the printer, there is a rename function. A little bit more complex, but works fine.
