Support should have been used, Cura is even saying its to use so much PLA and so much PVA. normal if you pick layer view and press play it will show the supports also like this.
Thing is the S5 should have stopped printing if the PVA was not coming out, did you see the printer at all moving the head to the right side between layers to swap print cores?
1
aag 2
these were the Cura settings.
