Marlin for Dual Extruder
aniketb
Posted · Marlin for Dual Extruder
Hello,
I am trying to use second extruder for support material. I made following changes in Marlin
1. In Configuration_adv.h
#define EXTRUDERS 2
2. In Configuration.h
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 1
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 1
I could see two different extruder temperatures on LCD screen but as I give print command, second extruder is not heating at all. I tried using Cura 12.12A, Cura 13.06.4 but none of them worked. Can anyone help me to sort out a build of Marlin which will enable the 2nd extruder, thermistor and heater ?
