3D Model of Ultimaker 3 Extended?
dmahalko
Posted · 3D Model of Ultimaker 3 Extended?
For what, to print a miniature or to build a clone?
If you want to build your own UM3, check the Ultimaker Github, there are all source files available.
    I am working on designing a nice looking, dust, moisture, fume, temperature stability environmental enclosure (planning to post about it separately) and would like a model to place inside it. Full model accuracy is not required, just the main body panels.
    Apparently those could be dug out of the github and manually assembled.
    Followup for anyone else looking for this.. after poking around a bit, it seems there is in fact a complete 147 megabyte STEP model of the UM3E lurking in the Github:
    https://github.com/Ultimaker/Ultimaker3Extended/blob/master/3D model Ultimaker 3 extended/9511.STEP.zip
    (FreeCAD was none too happy about opening this massive STEP file, but it did finally open after about 10 minutes of Not Responding. For my mockup modeling purposes I can delete about 80-90% of the internal, non-visible, or very small parts.)
          • Confused
        • 6 replies
