Cura 3.6.0 release Ultimaker Original+ problem with firmware update
indefix123
Posted · Cura 3.6.0 release Ultimaker Original+ problem with firmware update
The firmware for the UMO+ included with the Cura 3.6.0 release does not function properly on UMO+ the problem is that the controller screen becomes illegible i.e. becomes blue. I had to load a previous firmware from an older Cura version 15.04.06 to make it work.
    The firmware updater has been changed though (as in: the part that flashes the firmware). Unfortunately, I don't have an UMO+ to test with.
    1 hour ago, yori said:
    same here. Are there any news to that issue?
    Ah, here is a lot more information about that. Thanks.
    Had the same issue with a UMO+, suspected the cables, changing the with another pair did work better.
    Another thing I noticed, removing the SD card, then restart the printer also worked. The issue does not go away, but something works... Did the update with 15.04.6 as well as 3.4.1.
