Well, it seems to me that the top and bottom engravings have narrower gaps than the sides. Compare the images below. If you look at the model using the Cura solid view, do all the engravings have roughly equal size gaps?
For the bottom layer, make sure that the z-height is not too low which would squish the filament out more.
Also, I would not use a brim for this model as the flat bottom is going to stick very well.
Here's the bottom and the gap between the outer walls is only about a line width wide.
Here's the side and the gap is more like 2 or more line widths wide
Thanks for the suggestions. I'll have a closer look at things in Inkscape and try to adjust.
You're right about the brim, after the first print it was clear that I didn't need it. Given the line that Cura now prints on the left of the build plate, I'm not sure I even need a skirt, which is what I normally do.
Thanks again for your help.
burtoogle 510
Hi, could you please attach either the gcode or the project file? Thanks.
