DSM - Arnitel ID 2060 HT
SandervG
Posted · DSM - Arnitel ID 2060 HT
DSM makes Arnitel ID 2060 HT available to Ultimaker users via our material alliance in Cura.
You can access all available materials via Cura > Marketplace > Materials.
Are you curious about others experiences using Arnitel ID 2060 HT or do you have any other questions regarding this filament? Feel free to post them below.
Some links you might find useful:
Technical Data Sheet
Safety Data Sheet
Printing Guidelines
    • 2 years later...
    Hi @JBTechnology83, thank you for your message and welcome to the community! Upon your response I noticed the printing guidelines link didn't work anymore so I updated it, apologies. When you click the new link you will find a pdf that will tell you:
    'Best adhesion with Arnitel® ID is established using an PEI sheet. Alternatively, double adhesive tape or film can be used as well. Larger footprint by adding a brim of at least 5 mm to the print helps adhesion and prevention of warpage.'
    We have a film that can be used; called adhesion sheets. You can find a support article about it here (although it is for UM3, instructions for an UMS5 would be similar). You should be able to find adhesion sheets with our resellers, hope this helps!
        • 16 replies
