I'll be setting up for testing shortly. Thank you for the profile. One thing I am trying to locate in the threads is minimum nozzle size. I know the CC red is 0.6. Is that assumed to be the minimum nozzle diameter? I have a potential application that would go all the way down to .25 (hardcore/everlast). I appreciate this would be experimental.
Thoughts?
John
I believe Owens Corning also did some tests with 0.4mm, but our profile is indeed limited to 0.6 due to the CC print core. I would be hesitant to go below 0.4 because of the fibers that are added to the material, they may end up clogging your nozzle if you go too small.
PaulK 14
The Owens-Corning datasheet says “>0.4 mm”
Paul (in Ottawa!)
SandervG 1,521
JohnInOttawa 104
Thanks for the verification @PaulK and @SandervG! Best wishes to you and yours in 2019!
John
