Unable to print with non NFC spools
V3DPrinting
Posted · Unable to print with non NFC spools
On 11/29/2018 at 3:26 PM, Smithy said:
Good news!
Don't forget to delete everything below the folder ~/Library/Application Support/cura, but double check that you have saved or written down all your profiles and customizations before.
I had some time this week and been able to re install everything not using any export.
It works ! Either on UM3 or S5.
The override issue on Cura Connect is only on the first material and on the S5. If you override the second material, the print starts without any issues.
        • 10 replies
