Thank you so much!
In my screenshot I have converted to voxel choosing 10,000,000 as voxel value and the edge still isn't sharp? Tried 15,000,000 but then my computer started to argue with me and wouldn't let me do anything smoothly afterwards.
Could you load my STL file and see what value you would choose?
This particular model is to be used as a lid on an small glass I have with salt water.
kmanstudios 1,117
Ahhhh, ok, here is the trick with getting something into 3D coat.
First off, if you are looking to add texture to the model, then you must convert to a volumetric object. BUT!! make a copy of the object then convert. Why? So you have a lo-rez proxy in back up.
Here is a quick breakdown on the basic interface as I use it for modeling:
A. This button will toggle you between orthographic and perspective modes.
B. Make sure you 'park' the 'Tool Options' to make it easy to get to things. Say, if you move and scale and rotate (transforms in 3D parlance) it will remember that. If you bring in a new model into a new blank layer, it will remember that. So, you just hit 'Reset Space' and it puts the transforms back to their original values.
C. This is the 'Ornament Alphas' I use for a lot of my decorative things. For instance, this is a set of transorms from 'JRO Tools.' Not that expensive and very, very useful. Can find on Gumroad easily. Can also just search as well.
D. I use the Polymer colours for colouring my models to differentiate between parts or just setting a base colour. Keeps you from getting the 'black' look you got on your model import.
E. VOX tools. I just put them there because I use them a bunch and want them very easily accessible.
F. Where you can increase resolution if you want to 'slow down' the effects of the tools. More on that in a moment.
G. This is the 'Duplicate Layer' button. I find this useful if I am doing work and want to save 'stages' of development.
Basic workflow I use.
Your interface does not look like mine, but you can move those interface sections around to suit your organizational desires.
Tools I use the most are at the top of the left hand side: Grow, Smooth, Scrape, Pinch, Smudge.
This should get you going enough to really play a bit.
kmanstudios 1,117
I forgot to add a clarifaction of nomenclature:
These two terms get used a lot interchangeably. This can cause issues until you can understand the context of their usage. For this thread, I will attempt to use These two terms as I have outlined in this post.
