8 hours ago, nallath said:You can also make material specific quality profiles. The UM3 and S5 have those. So it's already entirely possible to do this.
Yea i figured that much and I did have a look at the UM-settings (i run UM3 as well), but I would need to make a Quality-setting for each material and then limit what Quality-settings are displayed based on the selected material, meaning I would need to make both Quality and Material setting for each materialtype, this pretty much makes the split between material and quality settings almost wasted...
In this case it would mean at least 3 default profiles for each of the follow filaments
PLA
PETG
TPU/Flex 98A (Probaby fine on the PLA-settings since retraction can be material-adjusted)
TPU/Flex 95A and lower (Because of different printspeed than 98A & PLA)
Wood
Nylon, PC-Materials, and other hard things
ABS & ASA
Just these would result in at least 21 Quality-profiles, but could have been 3 if materialsettings could affect speed and we need to make the material profiles anyway...
Am i missing something or does it kind of make sense?
nallath 1,117
