Creality CR-X driver for Mac?
  • 1 month later...
  • 1 month later...
Posted · Creality CR-X driver for Mac?
Follow these instructions here:
 https://www.thingiverse.com/groups/creality-cr-x/forums/general/topic:33324#comment-2194035
(tl;dr : copy Definition and Extruder json files into the package contents. Then you can create a CR-X)
You can mostly then use the settings from the Creality cura docs on the SD card.
I've encountered a bug in which Extruder Start/End Gcode isn't inserted properly. You can work around that as discussed here:
https://www.thingiverse.com/groups/creality-cr-x/forums/general/topic:33324#comment-2332745
