Hi Smithy,
many thanks for your support.
My plan is printing on textiles. Due to high elasticity of textiles I thought about building a tentering frame, that should be placed at building plate. Could you suggest an approximate weight for the maximum load? Or what's your experience on the weight of usual models?
thanks
Smithy 1,114
Hi Barbara - welcome on board!
Regarding your first question, the heating element is underneath the aluminum plate below the glass. So when the bed is heated up the heating element heats up the aluminum plate which then heats up the glass.
For the second question, I don't understand what you mean or what you want to build. But regarding weight, I have not seen any numbers or recommendations yet about how much weight can be put on the build plate, but I would not go much higher than the weight of the usual models. Some users pause their print and put some weight (sand) inside the model, so a little bit more is possible, but you should avoid that the bed is hanging lower in the front than in the back due too much weight.
