Yup, just found it! I should have looked just a little harder 😞 Thanks!
On 12/10/2018 at 8:59 AM, danilius said:Yup, just found it! I should have looked just a little harder 😞 Thanks!
I didn't find it. Can you tell me where it is, please?
Have you read the thread linked above? Hint: Materials pane of the preferences, or install the Printer Settings plugin from the marketplace.
Edited by ahoebenOn 12/13/2018 at 9:36 AM, ahoeben said:Have you read the thread linked above? Hint: Materials pane of the preferences, or install the Printer Settings plugin from the marketplace.
Yes, I read it, but doesn't help. In material panel have .... materials, which values can be edit. In marcetplace I didn't find Printer Settings plugin. In this case I'm pretty sure v3.5 is better. Maybe I'll migrate to older version.
Smithy 1,134
Check this thread:
