Yet another multi-nozzle tool head design for UM2/2+
Posted · Yet another multi-nozzle tool head design for UM2/2+
Hi guys,
At the end of this year, I would like to share my design of a multi-nozzle tool head. A year ago I've posted some results of dual material 3d printing on my DIY Ultimaker 2  on G+ ( G+ link) I said there I used a different approach which has not been implemented (at least I didn’t find) elsewhere.
Well, the nozzle changing idea I came up with was inspired by the multi-lens microscope (where three or four lenses are distributed around an axis, mounted on a plate. To change from one to another, one can simply rotate the whole plate so that the lens engaging is pointing towards the object).
Took this idea, I replace the lenses with nozzles. For example, given three E3D kraken style heat breaks, heat blocks and nozzles distributes around a slightly leaned axis, at an even angle. The axis is leaned at a certain angle to ensure the nozzle engaged will be pointing perpendicularly towards the heated bed.
Then the heat breaks will be inserted and mounted into a single heatsink.
At the top of the heatsink a large 6807zz bearing is inserted to ensure the rotation with the given axis. Actually we use two bearings for the axis to avoid wobbling when performing the rotation.
But a free rotation is not what we want, for the engaged nozzle will rotates away by fiction. To implement the intermittent rotation, I used the Geneva mechanism, as you can see the Geneva wheel is fixed in the back side of the heatsink. So that the drive gear rotates, drives the Geneva wheel rotates. And when the engaged nozzle is printing, Geneva wheel is constrained so that the rotation freedom is eliminated.
To drive the gear, many approaches can be used. For simplicity, I took the mechanical way (inspired by the Ultimaker 3). I used a rack to drive the gear. So that if the rack is pushed from either sides, the drive gear rotates.
To do that, two rods must be mounted on each sides of the printer, so that if the tool head moves towards the end of the rod, the rack will be pushed.
Then a printed pivot part will connects these components together. The pivot part is also good for holding all the wires and Bowden tubes, which will be connected to the nozzles.
Then comes with the printed enclosure and two fans. The left axial fan is for cooling the heatsink, and the right blower fan is for cooling the printed parts.
Finally, at the bottom a sheet metal piece is mounted to the enclosure to prevent oozing from un-used nozzle. Also a printed shroud guides the air flow out from the blower fan to the printed parts.
Currently the whole tool head design can be used as a module for UM2. The rack can be pushed by two rods which are fixed on two sides of the wall of the UM2 machine.
10.thumb.png.c765668c3de0610cadc5335d60644550.png11.thumb.png.e2a0b741b1fb388a19a3849e54246033.png12.thumb.png.e2232bf06940b93c55542a81b1330635.png
As you may see here currently only two nozzles have been mounted. The repeat accuracy is impressive, I’ve printed a lot of dual-extrusion models, such as the Gyro, the traffic cone, the hand-drill and also a strandbeest I designed on thingiverse (https://www.thingiverse.com/thing:3263196).
I’m working on the hardware and software to make three nozzle printing possible.
Also, I’m trying to make this design more compact. The heatsink part needs to be simplified, improved, for easy making. And I have not give a good name for this tool head.
So please help me to improve it! Any ideas, comments, names are appreciated! Also I’ve some spared parts, I’ll be very happy to help you to try this out.
Best,
XJ
  • Like 7
I like the fine and inventive engineering of this, with that geneva switching mechanism, leak guards, airflow directors, etc... If you could indeed make it more compact, it has the potential to become a hit, I think. Very well done.
    • 2 months later...
    Hi @jphermans,
    Not yet! I'm redesigning the heatsink now. The problem with current design was the cost of machining the heatsink parts. And the whole design looked a little bit beefy too. That been said, the modified firmware for this printhead has been already shared at https://github.com/tigertooth4/Ultimaker2Marlin . I'll try to make the CAD file available as soon as I can.
    The current design did print amazingly well. I've done a lot of dual extrusion prints (mostly with PVA supports) with this printhead. Please check my instagram page (https://www.instagram.com/tigertooth4/)  for more recent prints I've done with the Revo printhead.
    Thanks very much!
    Best,
    XJ
