Thank you Smithy, I have also tried that but that didn't do the trick either.
Yes everything back as if it had just come out of the box.
And I guess you also used the correct firmware UM2 vs UM2+, because there is a difference between them.
Then I have currently no more idea because with the stock firmware you don't have many possibilities. And the feeder itself is ok? Maybe it is a hardware problem with the feeder and not a firmware issue with the e-steps.
Yes the correct firmware was used. I thought a long the same lines with the feeder possibly being the issue but I fitted it to another machine running stock firmware and all seems to be working fine. Its very confusing. I've even tried a new motor to see if that was the problem but always the same outcome. Thank you for your help though
One more idea, but I don't know if it helps.
Install again Tinker FW, do a factory reset, enter the needed value for e-steps. Try it if it works.
Then install stock firmware again, do a factory reset and try again.
I'll give it ago. Thanks again.
Tried but no luck. Could the E-steps be stored somewhere the reset isn't touching?
I used Cura to send some G-code to the printer to calculate E-steps. I found that after extruding 100mm in extruded exactly half (50mm)
So I set the E-steps value to 738 double the preset value and the filament now looks like it will move the entire length of the bowden tube but the motor seems to be having issues. It makes a whirring sound and the filament skips as its being moved up the tube. I vaguely read somewhere about the motor settings needing changing after the e-steps value being altered but I can't for the life of me find it again.
Did a test print, and the print was perfect. It's just the changing of material that now has this weird problem.
tinkergnome 839
13 hours ago, Thirtythree3d said:So I set the E-steps value to 738 double the preset value
Sounds like you are using the UM2 feeder motor with the UM2+ feeder (the UM2 motor has a step angle of 0.9 degree, the UM2+ motor 1.8 degree).
As soon as you change it back to the correct motor/feeder combination you should be back in business...
I will give that a go thank you.
On 12/13/2018 at 12:54 PM, Thirtythree3d said:Yes everything back as if it had just come out of the box.
Everything, except the motor? 🙂
Looking that way. I'll report back as soon as I get the chance to switch it over.
I did indeed have the wrong motor fitted. I replaced the motor with the correct one but the problem still exists. Any other ideas?
tinkergnome 839
4 hours ago, Thirtythree3d said:I did indeed have the wrong motor fitted. I replaced the motor with the correct one but the problem still exists. Any other ideas?
Have you set the e-steps back to the default 369 steps/mm?
(assuming that we are still talking about an unmodified UM2+)
Yes everything set back to default and yes unmodified.
Ok I started thinking out of the box. I installed Ultimaker 2 firmware and then 2+. Then a factory reset. It now works as it it should. I'm thinking this was once an Ultimaker 2 with an official + upgrade.
Thank you guys for all your help.
Thanks for following up and great that your printer is now working again.
Smithy 761
The factory reset should be done AFTER the firmware change, so it should be your very first action with the new firmware.
