Hi Geert,
Thanks for taking the time to look at my case!
Of course, my printer is an Ultimaker (2+ Ext). For a short while, I thought that a ball bearing might be broken but, I think there is no ball bearing on that shaft, only a brass sleeve. I just lubricated the shaft (using the grease supplied with the machine) and slided it many times (with the power turned off). Then I tried another print and got the same vibration.
With the power turned off, I moved the extruder and felt the vibration and hear a noise. I think it comes from the bearing but that's difficult to be sure. Could it be a stepper motor?
We own two identical Ultimakers, of course the second one don't vibrate and make no sound while the extruder is moving toward the y axis.
I'll make another print attempt placing the cube somewhere else on the bed to determine if the same vibration will occur...
Best regards
geert_2 557
Did you check if the rods are well oiled? With the printer off, if you move the head by hand, it should move reasonably smoothly in all directions. At least, if it is an Ultimaker; I don't know about other brands with other drive mechanisms.
If it would only be a visual effect, without mechanical shaking (especially in an Ultimaker2), it could be caused by a tight bending radius of the filament (e.g. near the end of the spool), causing a lot of friction in the nozzle and bowden tube, and thus causing underextrusion?
