Print-quality
liba
Posted · Print-quality
I can only see the model files and not the Cura profile!
The pictures look a bit like some of my failed prints when "enable gradual infill" if its one, so try and turn it off, if on. This setting fucks up my S5 more then anything. (maybe it has changed in later Cura versions)
And like mentioned before the print temperature looks way to hot.
(dont know if there can be a setting overriding your custom set temperature?)
    The cube looks quite okay, I think.
    Could it be that the round object has too many triangles, thus way too many segments on each circumference? I vaguely remember that this has caused similar issues for other people in the pas?.
    I would suggest you design a new simple round button, and save that as STL with not too much segments. And then try again.
