Thanks for your speedy reply,I have used the same cable for my HP desk jet and that works fine.
the only trouble is that to control the printing speed I need to be able to edit the SD file but I don't know how as I am still learning
the whole 3D printing system.
Thanks again Eric
Smithy 1,146
Hi
if you can print from the SD card but not when connected via USB, then it could be probably the USB cable. Try if another one works.
Generally, printing via USB is not recommended, it works but is not as reliable as via SD card.
