Posted · Bad tool paths
I have a couple of small box models I have printed a couple of times. The walls are too thin for infill but they are just 3-5 passes of the print head. The problem is that they take a ridiculous amount of time to print. I’ve watched them a bit and noticed that the print has a really bad pattern. Instead of a continuous line for all of the passes, it will print a line on the short side then travel along three sides before starting to print again and then it just prints the three sides it had just traveled over. Where do I start to figure out why the slicer is generating terrible tool paths.
    I'm currently trying to print this design from Thingiverse: https://www.thingiverse.com/thing:2694475
    All I did was open them in Cura and arrange the models and hit prepare. I've attached a screenshot of the layer view with just the travel paths. May be hard to see, but it's traveling the whole perimeter of both models multiple times per layer.
    I also took a screenshot with the shell paths turned on to show the overlap of them. I would think the only travel that's really needed is going from the starting corner of one model to the starting corner of the other for each layer.
    Is there a good way to measure the starting coordinate? When I just set it to User Specified, it set the Z Seam Y to 630mm - a bit outside the 200mm build plate.
    I was expecting more time saved, but it seems like it's only shaving a few minutes off. Though the estimates are inexplicably double what they were last time I checked. No other settings changed, so I'm just more baffled.
