On 12/18/2018 at 7:25 AM, SandervG said:We're not only trying to always make Ultimaker Cura better with the usual new features and improvements we build, but we're also trying to make it more pleasant to operate. The interface was the focus for the upcoming release, from which we would already like to present you the first glance.
Because we're still working towards the stable version we would really like to receive your feedback! Do realize it's an early beta version and we can't guarantee the same print reliability as our stable versions.
So, what is new exactly with Ultimaker Cura's new interface?
- Based on user research we've build a smoother, more logical workflow
- New user account control panel for plugins that need a login (like Cura backups)
- Quick and easy access to the Marketplace
The workflow
In the new UI you can find three steps in the header: Prepare, Preview and Monitor.
Prepare is where you configure your settings or profile, Preview shows you the layer preview and time specifications and in Monitor you can send and monitor your print via Cura Connect.
The header contains of collapsible panels that don't take up any space or distractions when you are not using them.
User accounts and Marketplace
The Marketplace has received a more prominent location in the interface, because we believe this will be of great value in the future. We've also integrated a new module for user account control, which some plugins require as the Cura Backup plugin you may already use. And more will follow in 2019 🙂
Curious to give it a try? Download it here.
And when you have, please let us know what you think below 🙂
kmanstudios 1,074
Sometimes a user may be pulling in things from disparate sources or positioning. Here is a good example.
So, to maximize space, it is good to take all these pieces from this type of source, without making a separate file, and gang them up for printing. I spend a good bit of time circling around the buildplate to make sure they do not interpenetrate.
I do have it set to not avoid models' bounding box so I can fill voids when needed or possible.
Brulti 174
Ok, I get it now. I usually print one object at a time myself, but now I see how it could be useful.
