It should work, but after you turn the machine on, it thinks it is at 0,0 so that command won't do a thing.
Try "G28", it should home then. After that "G1 F3600 X100 Y100"
I see , Thanks Daid
gr5 2,070
I don't think that works anymore. I recommend you use pronterface. It's free and great for playing with gcodes. It can also send a gcode file to the printer instead of using cura and people say it's more dependable but I wouldn't know.
