G Code Flavor
Posted · G Code Flavor
I am working on Zmorph 2.0 3D printer and i will want to work with the Cura 2 3d programm. That program has not the Zmorth printer in the list and from tutorials at cura's site i choose ''custom printer''. I set the dismensions of the the table and and the printer head als,etc. I can still choose the g code flavor because i can't know the software of 3d printer. I haven't the serial number of the printer because i get it from one parter.
Thank you
Nickos
    Not sure why you should need the serial number?
    The gcode flavor should be set to the flavor used by your printer. I don't know your printer, but most of the printer are using Marlin firmware, so chances are high that it will work with your printer.
        • 4 replies
