Eliminate the z hop dot
schafe
Posted · Eliminate the z hop dot
On almost everything I print there are many many times when the printer will retract, z hop to a position, deretract, make an imperceptible x/y move placing just a dot, retract, then z hop to another position.  What setting do I need experiment with to eliminate what seems to me like a wasted step?
Thanks
    Watching the animation of the print, I see these dots are often the very last step before a new layer.  In the attached g code at layer 48 you see the printer is adding tiny spots of infill - yellow.  It happens a lot on this project due to the many spikes, but I see it on almost all of my prints.  If needed, I can video a print in progress.
    If someone is feeling extra generous, I have included the Cura settings I use.  I'd like to know if someone sees something way off from the norm.  I am having a difficult time getting satisfactory results lately.  The only thing that seems to work is to slow the print speed which makes me sad.
    If it makes a difference, I am using an Ultimaker 2.
    Thanks for the help.  Happy Holidays.
    my settings.curaproject.3mf
    wade hedge hog.stl
    wade hedge hog.gcode
