Cylinder not printing vertical
Bedwarmer
Posted · Cylinder not printing vertical
Does anyone have any ideas. I print a cube with holes in each face. But not right through . Printer does not print the wholes that are on top or bottom . If i rotate the cube . Still the same. Can someone help please?
    Is this from sketchup?  If so here is some advice.  Mostly just follow the advice about inside versus outside surfaces (right click in sketchup and swap):
    https://i.materialise.com/blog/3d-printing-with-sketchup/
    If it's not sketchup or if you didn't create the model, maybe try:
    netfabb free repair service is here (you have to create a free acocunt first):
    https://service.netfabb.com/login.php
    Thankyou. Yes i am using sketchup . I will have a look when i get time.
