3 hours ago, gr5 said:I thought someone might answer by now. In general I get better quality if the speeds are all the same - every speedup or slowdown causes over or underextrusion and I get these bumps like this. Also printing slower is better as then the pressure is lower in the nozzle and less likely to splurt out like this.
So set all 7 or so printing speeds to be 25mm/sec (I know - slow) to see if that helps. Leave the travel speed >= 150mm/sec.
So I tried some of the settings you suggested, only changing the settings above 25mm/s to it and leaving the rest that were slower than 25mm/s. However, I still got the same resulting bumps, which the only difference was that they were a tiny bit smaller.
- Combing turned off did fix those random lines on the deck.
- I stopped the print early because the rest of Benchy isn't necessary to for this problem.
**Ultimaker Cura settings used. The speeds changed to 25mm/s were originally faster than that, and I left the slower speeds.**
**TOP/SIDE 1 VIEW: There are no visible lines on the top, turning combing off did work in fixing this. However, the bumps are still visible on the side.**
**SIDE VIEWS: The bumps are still present in the same locations as before, just a tiny bit smaller.**
gr5 2,069
