2 hours ago, gr5 said:In cura the print bed is shown with a checkerboard pattern. These are 1cm by 1cm. Check to see if this agrees with your part. If it does and you slice it then it will have gcodes scaled to mm.
If you then print it and it's 5X too small there is something wrong with your printer - it's not taking gcodes scaled to mm.
For example:
G0 X100 Y100 E0
G0 X120 Y100 E2
The first command puts the print head at position 100,100 and then the second command moves 20mm to the right and extrudes 2mm of filament. These values are all in mm. Maybe your printer is in some other unit? Maybe you have the steps/mm set up wrong on the printer.
Thanks for the reply gr5,
As I mentioned, I'm a 3D brinting newb, so, I don't even have experience sending gcode commands yet. I will certainly look into this, as I do know installing Octoprint will allow me to send commands via usb.
How would I go about finding the units setting on the Ender 3? I've explored all menus for exactly that and can't find it. i will revisit the documentation again to see if I've missed it somehow.
Thanks again
gr5 1,870
For example:
G0 X100 Y100 E0
G0 X120 Y100 E2
