The version of Sidebar GUI with an undockable sidebar has been released on the Marketplace for your undocking pleasure.
- 3
Please help testing this development snapshot of Sidebar GUI which adds compatibility with Cura 4.11.
You know the drill: download the file and drop it onto the buildvolume in Cura.
Unfortunately, it does not look to function on my end with the 4.11 Beta. I also didn't see anything in the logs that indicated an issue with it loading.
I hope I'm missing something simple, because this is the only plugin I look forward to with each Cura release :P
Thanks for testing! Could you try this development snapshot instead?
The v7.0.0 in the filename refers to the SDK version, not the plugin version.
No issue for me ! thanks a lot
It is collapsible. See the little down-arrow next to where it says "Compatibility mode".
I never played with that. I figured it had to do with the graphics mode. OK, you're off the hook for now. Thanks.
I’m always on-hook…
I may have mentioned this before, but because the plugin does a lot of in-place patching of QML, which can break horribly if the original QML has changed in a version upgrade, I have put in a mechanism in the plugin that it ALWAYS needs an update when a new version of Cura is released. ALWAYS. I'll have a link to a development snapshot here soon.
Edited by ahoebenThank You.
I understand I'm working with a Cura beta version but I've gotten used to the interface with the plugin active and I miss it when it's gone.
You are so right @GregValiant, using Cura without the Sidebar plugin is like eating a burger without a patty 🙂
Careful @Smithy...the Vegans are watching.
Sorry for the delay, here's a development snapshot. Download the file, drop it onto the buildplate in Cura.
Thank's a lot .. So much more user friendly than the standard interface, I don't understand why this is not the standard for Cura?
29 minutes ago, Cuq said:Thank's a lot .. So much more user friendly than the standard interface, I don't understand why this is not the standard for Cura?
It's a long story, so I won't bother people with it. We are looking into changes that we can make in the interface as it is now.
Hey, I see you also found the new icon for the measuretool already (that was quick!).
24 minutes ago, ahoeben said:Hey, I see you also found the new icon for the measuretool already (that was quick!).
An other tool which should be a standard function !
Top Posters In This Topic
49
11
7
6
Popular Days
Jan 8
14
Jun 2
7
Nov 4
6
Sep 1
5
ahoeben 49 posts
GregValiant 11 posts
OUPS65 7 posts
Smithy 6 posts
Popular Days
Jan 8 2019
Jun 2 2019
Nov 4 2021
Sep 1 2021
Popular Posts
ahoeben
I'm working on a plugin that changes the new GUI in Cura to be more settings-centric by adding back the concept of a sidebar. If you can't get used to the floating panels in the new GUI, there will so
ahoeben
A test-version that should work with both Cura 4.0 and Cura 4.1 is available here: http://files.fieldofview.com/cura/SidebarGUIPlugin-v6.0.0-2019-06-11T21_09_03Z.curapackage Download the file, and d
ahoeben
A new version of the plugin is available from the Marketplace, with full support for Cura 4.0-4.8. The sidebar can be collapsed to a summary for all of them.
Posted Images
GregValiant 1,251
All that time typing and all I had to say was thank you.
