Hi Geert,
I'll try if swapping the USB drive makes any difference, thanks for the tip.
Hi Geert,
Try turning off autolevel to see if the problem goes away. If it is indeed an autolevel problem, flip open the front door on the print head and look in the base of the head and there should be a white, flat circuit board with 2 wires going to it. Check that both wires are connected. Also remove the rear panel at the top of the print head by removing the two long screws and then it just pops off. Push down firmly on the cable in there, and then put it back together.
geert_2 556
I don't have an UM3, so I can't comment on the print cores.
But maybe you could also check the SD-card? It could be a damaged card too, or dirt in the connections. Or a damaged file, incorrectly sliced or written (e.g. empty)? Or check connection if via USB?
