1 hour ago, Creator_TIm said:One of them had a per model setting for the infill
Wait, did you change the "Mesh type", or did you add a setting using the "Add settings" button?
No I didn't change the Mesh type. Just the Infill type. And I didn't add settings.
On 1/9/2019 at 9:24 PM, ahoeben said:Check the slice in Layer view. Does the model show there?
Well it shows the model, but its grey.
I’m going to need a screenshot, with the Per Model Settings panel showing what you changed.
ahoeben 1,850
