I attached
Hello @Kari, thanks for the gcode. It has been generated suitable for a printer whose origin is in the centre of the build plate. You need to check the Cura machine settings for your printer and make sure that the Origin At Centre checkbox is not enabled.
1
Hello @smartavionics! It was the problem!! I did a test and It is working now. Thank you so much!
Do you have a tutorial or guide for setting the Cura correctly? Or, do you know where I can found it?
8 minutes ago, Kari said:Do you have a tutorial or guide for setting the Cura correctly? Or, do you know where I can found it?
Sorry, no, I don't, but perhaps others on this forum know where useful info can be found.
OK. Thanks!
Hello Kari
you can find some information here:
https://ultimaker.com/en/resources/21932-mastering-cura
or here
https://all3dp.com/1/cura-tutorial-software-slicer-cura-3d/
- 1 year later...
Hello
I do have the same issue, i made just a test cube and placed it on the center of the bed.
I have a custum setup printer (FLSun i3 large) and ticked "Center" on.
Still, it starts to print on the corner. Cura V4.5
With Cura 15.04 there was no issue.
OK,
I misread, the Origin at center should NOT be ticked on. Lets try again :)
burtoogle 506
Please attach the gcode so we can see what's happening. Thanks.
