It is possible that it is the model itself if the object is not lying flat on the build plate, you print in the air and if this is only a few microns then you don't see it on the first sight. But you can check it in Cura if you rotate the build plate to get a look at the underside. Check if the whole bottom is red, then it is actually touching the build plate.
To try another object is a good idea, download any object you like from Thingiverse, there are a lot of 🙂
You can also enable the option "Automatically drop models to the build plate" in the Cura preferences, which should automatically put the object on the build plate.
Smithy 1,141
Hi Fabian and welcome aboard!
Are you sure you have calibrated your bed correctly? It looks like, your nozzle is too far away from the bed.
Advanced 2
Hi Smithy,
I used the plastic card and second the paper calibration card at the 5 calibration points, and set the distance so that the paper between bed and nozzle have some resistance if i move it. Should be fine i guess?
However as you see in the picture, the bottom of the model is not accurate, but the top is perfect.
Could that be the file as well? I wonder why the printer is able to print a perfect adhesion plate, but the model then becomes that bad?
Do you have a test-print file which i could try to figure that out?
Best,
Fabian
