It would be nice to see more photos of the shift - especially ones that show the worst shift.
One possibility is that you have "play" or "backlash" (look it up in wikipedia). With printers that have noticable backlash if you print the same layer clockwise versus counter clockwise you can get shifts like you seem to describe.
I would check to see if the shifted layers are CW and the unshifted layers are CCW (or opposite).
Many times people have reported a bug in cura versus some other slicer only to find out that it was a hardware issue and the only difference in slicers was some minor speed difference, CW versus CCW, "wipe distance" or other minor thing. Sometimes a tiny change that shouldn't affect the print does affect the print.
- 1
baxi 2
Finished now the slow print, speed 40/20, Acceleration 300, Jerk 7.
No change, the line shift is still there.
redslifer 2
This is the (well, one of the multiple reasons) I abandoned cura. I never found a way to print a benchy without the split on that section, all the benchies I tried separated on that layer like if they were printed separately.
This never happened with any other slicer, and I don't use jerk and acceleration either actually, or at least I tried both ways before.
This along with the bugs that corrupts cura 4.0 machines and profiles at every restart (very common bug since 4.0, I read about it everyday...) made it impossible to use Cura for any purpose.
This said.. the split happens on the first "top" layer, that's where the material on the top doesn't bond at all with the one under it, it's not like it partially melts in some points, it just doesn't on any point. As I said, they seem printed separately.
neotko 1,417
The slower the acceleration and jerk the bigger the issue. Assuming you have a um2 it should be 3000/20
Try to print it rotated 45 degrees. If the problem goes away I would triple check also x/y alignment of the axis
Smithy 1,145
I see similar issues on some objects and I also did some tests some time ago. But I cannot confirm it is a slicer issue, I sliced it with Cura and S3D, both with the same result. It also depends on the color of the filament how much you see.
For me, I did several calibrations on the x/y axles, but it was not the problem. I still think it is some kind of over/under extrusion in combination with speed and temperature. But I stopped investigating deeper, so I really appreciate the test series from baxi, which give a great overview of the problem.
baxi 2
Thx for your ideas.
Maybe I will try higher acc later.
I already turned the print with no change in the shift. So it's not an axis problem.
