On 1/24/2019 at 2:36 PM, nallath said:You should contact your reseller. They should have access to SD cards that you can use to re-flash the firmware. Alternatively, you could also try to see if the slowness is gone if you don't connect the printer to the network (which is probably best done by temporarily blocking it in the router)
There isn't much other advice I can give you, as the factory reset is only accessible by the menu.
Thanks for the advice, denied it access to our wifi and now operating as normal.
Paul
nallath 1,117
