Just upgrading the version number of that plugin should do the trick.   I've tried to see if I could find some documentation that I can provide that provides a bit more imidate gratification. A fair bit can be found on https://github.com/Ultimaker/Cura/wiki/Definition-Files-Explained From there you can see that machines can define a number of things it actually supports. As there is quite a bit of things a given machine can say it supports, it's a bit tricky to give a single an
