Tree Support Misalignment when Importing from Meshmixer
Stenrik
Posted (edited) · Tree Support Misalignment when Importing from Meshmixer
I am having a difficult time with tree supports generated and exported from Meshmixer.  I painstakingly generated them on this complex model with the hope of importing them into Cura.  I brought my support in, then imported the model itself and zero it out.  However, I just can't get the two to align such that the tip of the supports is touching the model.  It is always offset by what looks like a millimeter or so.
In Meshmixer:
2019-02-03_104719.thumb.png.93cb47c205b4dc5bd60a11f52e898200.png\
Just the supports in Cura (does the striping mean something is wrong?)
Both in Cura:
Closeup demonstrating the support offsets:
How do I ensure the supports line up correctly?
Also, a follow-up question:  The plan was to use ABS for the main and HIPS for the support, or one kind of PLA for the main and another (cheaper) kind for the support, so that it's easier to see what to remove on a model like this.  Curious if anyone has thoughts on whether it's better to just better to disable Extruder 2 and print all with the same material for a complex model.
Many thanks!
Edited by Stenrik
    Is there a reason you can't export the model with support from Meshmixer as one STL file and then import that into Cura?  I would think they would be aligned for sure then.
    Do you have "Automatically drop models to the build plate" turned off in Cura's preferences?  If it's turned on, it could be inadvertently shifting your models' positions.
    The striping usually means that the object is too large for your printer's build area or it is located out of the build area.
    Edited by rowiac
