Smithy, I did that before posting, and, as the picture shows, it moves the object on the z axis, but the slicer doesn't care, it will slice the object from the bed up. In the meantime i've found an improvised and not at all ideal way into tricking the software it's printing from the bottom up, by adding a thin extruded tube far enough from the object so it doesn't hit it, and then it connects to the last layer via a thin horizontal tube. It does the trick, but it had to be aligned manually with the previous position, because the extra tubes had shifted the center of the object. Not ideal
It is strange, and there was a thread a few days ago with the same problem. I cannot remember the outcome, but I assume it is a bug in Cura. Because the solid view and layer view should be the same.
Maybe you could in CAD model a couple of little dots on the floor, separate from the real model? Then these dots will sit on the glass. All the rest will be at the desired height above it.
The idea would be a bit similar to the cross-hairs in printing, to align the different ink colors cyan, magenta, yellow and black.
- 4 months later...
Disabling "Remove Empty First Layers" allowed to slice in mid-air.
2
2
- 6 months later...
i am also try to print mid air right now
- 1 year later...
On 7/5/2019 at 6:22 PM, usonic said:Disabling "Remove Empty First Layers" allowed to slice in mid-air.
this did the trick. thanks
1
Smithy 1,132
You can try if it helps when you turn off this option:
I guess not, but give it a try.
